OEM backup camera?
Ferndale, Washington, USA
Lots of info on aftermarket cams but can't find anything on OEM. If i find an OEM cam off another fiesta/focus what else is needed to install it? does the ST wiring harness accept it and just plug and play then change something in forscan?
flbchbm
Sterling, VA, USA
I'm not an expert since I have a '19, but I've read on here the APIM (tablet) has to be modified w/ForScan to know that it has one. IF and only if it's possible. I bet if you search "backup cam" or "backup camera" you will find your answer. Your model year is a factor, I think.
flbchbm
Sterling, VA, USA
G
