2015, 35k miles, Stage 3, e-tuned, zero issues since new. My weekly driving route rarely varies and my driving style is always the same/sane.
I used to run a 93 tune, max boost psi 24.5ish & avg 31mpg in mixed driving
I currently am running a 91 tune, max boost 24.5ish & avg 32 in mixed driving. Low boost slot limits boost to 10ish boost psi.
Every once in a while my boost is capped at 15.5ish psi and subsequently my mpg falls to around 17mpg. Cycling between slots doesn't correct the issue nor does restarting the engine. No boost leaks or any other issue to be discovered.
Any thought? TIA
Any thought? TIA
