Now where to go.
Johnson city
I have have done cold air intake. downpipe, exhaust, cobb stage three, intercooler, and sub frame connectors. Besides new rims and tires, or turbo upgrade, and anything for looks what else is their to do for more speed/hp
? Thanks.
San Diego
Get an etune. Makes a nice difference over the OTS. I also did an E30 etune, big difference! I got mine from Adam@MAPerformance.
Miami
Charge pipes
Silicone induction hose
Inlet elbow
Throttle body and intake manifold spacers
Turbosmart BOV and IWG
All these will help maximize airflow, and the BOV/IWG will aid in turbo/boost efficiency so you can get the most out of a custom tune. They are also relatively cheap and easy to install.
If you wanna get fancy without swapping turbos, you can also go with a new turbo manifold and more aggressive cams. Though, now your getting into "turbo-swap" level of labor and money.
Also, don't underestimate the benefits of reducing rotational mass from swapping out the stock wheels for lightweight options. When you can't increase power, decrease weight!
M
Johnson city
Thanks guys for the feed back. I think I will start with the Turbosmart BOV and IWG, then get the tune. I thought I was done I guess their is still a lot to be done. Keep the ideas coming thanks.
Miami
To be honest, it's a finite system, so with the parts you have and what I mentioned, there's little left on the table besides turbo and internal engine mods.
Maximize air in: bigger, less restrictive hoses and pipes, intake, spacers
Minimize temperatures: intercooler, radiator, oil cooler, intake
Maximize air out: catless downpipe, high flow exhaust
Maximize turbo efficiency: BOV/IWG, manifold, inlet elbow, turbo core
Decrease rotational mass: lightweight wheels, driveshaft, flywheel
Maximize engine potential: cams, forged pistons/rods, custom ecu mapping, good gas
And remember, power without traction is useless. Good tires and subframe bracing help, so does an lsd.
ETA: What the other members posted doesn't increase power, however it increases driveability which translates to quicker times, which is the end goal anyway, right? Transmission plate, aluminum bushings and brakes definitely won't hurt.
You can also throw in "insurance" mods like an oil catch can and crankcase breather to give you peace of mind.
Miami
PM the MAPerformance guy on here for that. There's a thread in the other sub forum too. They are the best tuners in town.
