Howdy everyone, I'm stumped. (Hi stumped, I'm dad!)
This past weekend I tore the car apart and installed a GFB DV+, a Tune+ Turbosmart Wastegate, and a Whoosh Turbo Elbow. I figured since these parts are all stacked on to each other I'd just do them all at once. After flashing a new tune for the wastegate, the car stopped making boost over 12psi. My AFRs are fine, idle is smooth, no misfiring, car is not pulling timing, etc etc. Just not making boost.
I sent data logs to my tuner (Adam at Tune+) and he agreed that it was either the wastegate actuator causing problems or a boost leak.
After a few days of dicking around with it, I took it to Cobb Surgeline here in Portland. They did a smoke test to look and confirmed that there were no boost/vac leaks and that everything was torqued down and plugged in correctly. They determined that the problem was either the wastegate or the DV+, but more likely the DV+ because the wastegate flapper was moving freely when pressurized (I don't know how they do this, but they said they sent 16 pounds of pressure through it and it opened, which means even if it were faulty it would be making at least 16psi, mechanical pressure).
So, we are leaning towards the DV being the problem. This weekend I'm going to flash my old tune and put my factory wastegate back on to rule that out as the problem (if the car makes boost then I've got a bad wastegate!), but I'm thinking it's the DV. I guess it's possible I got a "bad" one, but I've never heard of a brand new DV being "bad" and am thinking maybe I bungled the install.
My question is, is there a way I could have installed the DV in that it would not function correctly, causing a loss of boost, but also not leak?
Thanks!
Thanks!
