Car has roughly 60K miles. Using a low-level shop computer I can see that the dash controls signal is reaching the ECU (A/C request signal), the A/C pressure sensor is reporting sufficient pressure, but some other criteria isn't being met and the ECU is not commanding the A/C clutch to engage (A/C compressor commanded state). The A/C fuse is OK, and I swapped the A/C clutch relay for one of the other similar relays and got no change. Anyone know what other criteria the ECU is looking to to be satisfied? I've found stuff about an ambient air temp sensor and a possible cylinder head temp sensor that need to be within spec, but the only thing I see odd in the shop computer is a IAT sensor 2 value that looks wrong. Don't we have just one IAT? Could that be the post-intercooler temp sensor?
