Posted this on my build thread. Figured it might be good to start a discussion here as others start using the RS-Pro.
I spent the day adjusting Federal tires again. The RS Pro was best at 33psi cold ~ 40psi hot, which seems high when compared to the 26/36 I usually run in the RT615K+. They rolled over if I ran anything less (
Atlanta Motorsports Park has a lot of elevation change and is extremely technical). It took longer (a few laps) to put heat in them compared to the RT615K+ (1.5 laps at the same track). Once they were up to temp, I enjoyed them and they became more predictable. Lateral grip is impressive but steering feedback was pretty numb. They "feel" softer than RT615K+. My biggest issue was in heavy braking zones. I activated ABS frequently whereas I’ve rarely done that with the Falkens. I also had much more tire spin accelerating out of turns than I did with the RT615K+ however, the RS Pro’s lateral grip at speed felt stronger. They held their line well on the long carousels. For that reason alone, I’ve decided to keep a set of them in rotation. I’ll see how they do at Barber in a couple of weeks. It’s also quite technical but speeds are much higher. I think the RS Pro likes heat, so higher speeds and harder braking zones might benefit them. It’ll be interesting to see what my lap times are with my new set of RT615K+ at the same track in similar conditions as well.
