*New Product* Pumaspeed Boost TAP
Trader history for pwnall1337 (0)
pwnall1337
Vendor
San Antonio
Pumaspeed Boost Tap for the Fiesta ST
  • Billet Alloy
  • CNC Machined
This adapter plate installs between the boost (MAP) sensor and mounting surface.
This allows a tap to run a vacuum operated valve or for connection to a boost gauge. When running this tap you are also able to retain your original engine cover.
This can be used for any situation where you require a boost/vaccum source such as the controller for a Water Methonal Injection kit or external mechanical BOV.
http://pwnallperformance.com/Fiesta-ST-Pumaspeed-Billet-Boost-Tap-_p_107.html
