http://www.pumaspeed.co.uk/product-Ford-EcoBoost-Bosch-MotorSport-HFHP-Fuel-Pump-200-Bar_17597.jsp
Bosch MotorSport High Pressure Fuel Pump 220 Bar - Pumaspeed
Genuine Bosch Motorsport Component
Direct bolt on but pipework will need to be changed to suit application
200-220 Bar Operating window without extra pump tappet load
At Last a high flow high pressure fuel pump for the EcoBoost motors.
This unit is a direct bolt on to the engine for all ecoboost engine and uses the same lift from the camshaft drive to give an operating pressure of over 200 bar without extra load on the tappet.
The Maximum fuel pressure the Ford stock ecoboost pump can create is around 180 Bar but at over 165 bar the load on the camshaft tappet is far too high and this leads to premature wear and eventual lack of fuel pressure and therefore power.
If your mapping does not take account for this lack of pressure you will damage the engine.
This Motorsport Pump will create over 200 bar without any extra load on the tappet.
The exit and entry ports may need small alterations to the conection pipes to affect installation on the EcoBoost engine of your choice.
