Cold Side Intercooler hose popping off
Denver
This is the second time this has happened. I have the Depo Racing intercooler with stock piping. I'll be cruising around (both times have been AFTER some spirited driving) and the cold side of the intercooler pipe will pop off. This is slightly annoying as i have to drive back home with no boost to get the hose back on. I am tightening the hose clamp until it wont turn anymore. Are there any other people who have encountered something similar or any suggestions to keep this from happening?
LilPartyBox
NYC
Get T-bolt clamps or an aftermarket charge pipe kit that includes t-bolt clamps.
Denver
Cool T bolt clamp looks good! Are there any gains to be had with the hard pipes? I mean if I'm going down there anyway i'm debating doing that... if there are no gains though then im not going to waste the money or time
Fort Wayne
I'd like to hear more what the car felt like with no boost. Was it extremely obvious? Did it drive OK except for being slower?
Denver
It was INCREDIBLY obvious lol!!!!! even in 3rd gear it couldn't even really get above 4k rpm. I switched map slots on the accessport to my low boost slot and that seemed to help a bit. But in terms of the driving it was fine just soooooooo slooowwwww no pull.... no.... nothing
Honolulu
According to Mishimoto, there's HP to be had with hard pipes. Check out their R&D thread on intercooler piping.
Kirkland
This just happened to my car....is there any way to get to the cold side of the intercooler to fix the clamp without taking off the whole damn bumper? I really hope so....thanks
Hijinx
U.S. Air Force Veteran
Auburn, AL, USA
If you like the look of hard pipes go for it, but otherwise keep your money and buy T-clamps.
Chandler/Overgaard
Should be pretty easy if you get the front end up on ramps or jack stands, I just went through and checked all my clamps recently without trouble. An old trick I use to make the connection stay on better is hairspray, as well as, t-bolt clamps. The hairspray is sticky when it drys and helps hold the hose. Just remember that if the hose fully blows off the intercooler or wherever the engine is consuming unfiltered air.
Kirkland
Thanks. I switched my map to the eco slot to prevent as much boost as possible. I also tried to slide the hose back on to the intercooler as best I could without tools or a ramp to prevent that dirty air as best I could. Once I get home i'm going to see what I can do to re-tighten the existing clamp...t-bolt clamps are getting ordered today as well.
