So I've had these on for enough miles to say what I think. These tires rock. There comfortable, take turns the same if not better than the stock tires, wet driving feels like its dry out, 1st gear pull = zero when spin(E30 protuned). Since these tires are a little taller than stock if your like me and front wheels are tucking tire if you hit a bump going around a fast turn it will rub the inner plastic fender liner( but it does have an awkward shape to it. I think because these tires have a softer side wall than the stock tires the only place I would not use them is a rough autox surface and I'm only saying than cause I'm tucking tire. There are griper tires but not gripier tires that you can drive daily, drive to the race track, have a blast, then drive home in the thunderstorm.
