New Big Brake (Rotor) Kit Option
Bangkok
look what I found on Malaysia Ford Parts
it's around $345 dollars but I believe they use 4x100 pattern in Asia
It would be nice to get just the bracket and get your own rotor
http://www.fordpartsmalaysia.com/fo...0-parts-accessories/ford-fiesta-big-brake-kit
I drove all the way down from Thailand to get this fitted, only to find, contrary to earlier correspondence, that they no longer stock them. It's a Taiwan supplied item. It is designed for the non-ST hubs and calipers so the ST calipers aren't likely to fit.
They had a new Thai supplied kit which was 310mm rotors but apparently won't fit under many 16" wheels.
MPA
STL
I've been e-mailing Mark about those front brackets too.
I bought the SVT front brackets after misreading another post a while back - have been trying like crazy to find the SVT rear brackets.Anyone on the SVT Forum wants to sell the whole rear together lol.
You should be able to buy a complete aftermarket caliper with bracket, just keep the caliper as a spare and use the bracket.
Sent from my SM-G870W using Tapatalk
CanadianGuy
Southern Ontario
Rock auto does have SVT rear calipers with bracket. I think
http://www.rockauto.com/en/moreinfo.php?pk=1790540&cc=1385557
http://www.rockauto.com/en/moreinfo.php?pk=1790548&cc=1385557
Someone should call Cardone and tell them of a new market opportunity. Stoptech still has the slotted rotors available as well.
Who will try? Maybe even offer a red paint job to resell...
^ I don't see why they wouldn't be. If you order by year and model, they should be correct.
MPA
STL
I'll send A-1 Cardone an e-mail and ask.
edit: Just sent it - asked if the calipers are aftermarket, and if they'd sell just the caliper. Also asked about the core return to confirm its just the caliper you need to return.
That's a good price considering I was quoted $!40 for a set of rear caliper brackets, which is nuts.
MPA
STL
Heard back already - they need the bracket back too. so you're at about $200 and you have 2 extra rear calipers.
Thank you for e-mailing us. These are the correct part numbers for this application. Sorry, we do not sell the brackets at this time, and the brackets may be renewal or OE. For a core, the brackets must be included.
So eat the cost of the core.
Philadelphia
Well... I'm going to give everyone the reasons I want focus svt front brake setup including calipers. 1. They're probably easier to get in an emergency. Crap happens and it usually happens when you least expect it. 2. In my opinion fiesta calipers (with the bracket) and focus rotors just don't seem symmetrical to me. Just reminds me of what rear brakes look like. (Much bigger rear rotor to caliper ratio)
Idk. Maybe it's just me. And I'm sure there's more then likely more 2 piece rotor setups available for it considering how long it's been out with a fair amount of ppl that make parts for it. Or is it just me??
So... Do they fit? Aka just bolt right up!!
Seattle
Hey guys. Digging up this old thread. I see Gold coast finally has brackets for 300mm SVT front rotors for the seemingly reasonable price of $125. My question is whether or not it's worth that plus the price of rotors ($100-150) for an extra 22mm over stock. The original kit was slated to be 326mm which is is almost 50mm bigger than stock. These would be used for street and some light to moderate track days. Thanks.
