Hi All,
I recently picked up a 2016 Fiesta ST from a member here, having a blast with it so far. I've noticed that when I do a pull, while monitoring the negative ignition correction, I get a (small) negative correction when I hit a bump in the road. On a smooth road when I do a pull, I generally get no negative correction. From what I have read, negative corrections are not necessarily bad. However, since it generally only happens if I hit a bump, should I check my spark plugs to ensure they are tightened correctly (or something else), or is this normal? Thank you.
