So as you all know, Sync 3 equipped ST's have two USB ports. My assortment of accessories require three data enabled USB ports. Plugging in a USB splitter/hub results in an error message on the touchscreen saying Sync 3 does not support USB hubs, and asks me to remove the hub. I don't need my accessories to be accessible at the same time, so technically I can unplug what I'm not using and plug in the device I want to use, but I don't like that plan. I want to leave them plugged in all the time. I'm fine with pushing a button to switch between USB devices, but I need to find some kind of splitter that isolates the devices and USB connections so that Sync 3 thinks there is one device plugged into the USB port and does not generate the aforementioned message about not supporting hubs.
Does anyone know what kind of splitter/isolator/hub to use so that I can keep everything plugged in and not receive the error message? Please let me know, and thank you all in advance!
