Hi guys,
Just wanted to share what I did for my cel codes. I have the mishi intake on my 2016. I can tell you I researched these intakes a lot. Besides some issues with some fitments on the female adapters on this kit, I believe the octopus adapter will not provide the Venturi effect to scavenge the evaporate gases properly. The car needs the movement of pressure from the Ic cold side pipe into the intake to be accelerated thru a t piece which narrows in the middle to draw and scavenge the gases. On the 2016s the t piece is attached to the intake tubing we remove to put the aftermarket intakes on. On the 2104 and 2015 the t piece and check valve are built into the evaporate tubing itself.
So I went and bought the evaporate hoses for a 2015 fiesta st and it is plug and play, snug tight oem fit on the 2016 and onto my mishimoto intake tubing directly. Costs about $80 at the dealer. Part number in the pics...good luck all.
