My Fake ST Build Has Started
S
Thread Starter #21
Ok update. Monday I did laundry. Tuesday I finished up the plumbing, hoses, cac, ac. Buttoned up front of engine. 2hr
Wed I got the front bumper hung then started looking into other not having any power. Door lock button worked and hvac light lite up when battery connected but thats it. 3hrs then gave up.
Studied wiring diagram and came to conclusion to just keep building interior, thinking I need the roof liner installed cause it has the key in car sensor, and since it's still in pieces. Turns out yup it need that black box next to the lights connected. It senses the key fob and let's the RFA modal do it's thing. It's thing is triggering the key state relays in the CJB. Seeing the dash light yup just got me going. I've been wrenching for almost 27years now and this finally made me feel feelings again.
Awesome project. My 2 cents on the rear lights, run the newer ones from the ST. They are nicer looking imho.
S
Thread Starter #24
Its ALIVE!!!!! Fired right up. Now to get this clutch and brakes bled out, and do a test burn out. If it wont smoke the tires, I'm taking it all back apart. New oil (it was new but drained during swap), new coolant, new transmissing shifty fluid, new brake fluid. Lights work, key fob works. rear windows dont roll down????? hmm. maybe i didnt connect doors yet cause i havnt installed seat belts yet. Need to connet abs sensors, those codes should clear. Airbag light should be my only light until I get a module. Should be able to get it buttoned up tonight. Got my Wrap ordered.
Think I have to. the SES dont light up, unless i got a fuse out.
You are incredibly productive with this thing. It’s a big job.
Thanks. Big yes, Hard no. All plug and play. But I do heavy line work every day, did a encore transmission thursday and a accent engine tuesday, hybrid sienna body wiring harness monday.
