Do note that the "spring19" code still works and applies to different products than the "Fall19" code. For their radiator, the fall code is a nogo. Spring code is 20%
"Summer" code also works and is 10%
Yes and No! If you try it on the standalone AP ($550) it doesn't work BUT, if you select the AP3+Air Filter combo ($559) it will give 10% off. So not too bad, basically a new AP for $510 and a free high flow air filter.
