Mountune Fiesta MRX Turbo
Albuquerque
Those lines were a pain. ATP sells braided lines that you can use instead.
Might be too much to ask, but can you post a link for those lines?
Edit
https://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-FIE-022&Category_Code=FIE
Is this it?
Cincinnati
I emailed ATP and they came back with this:
Yes the lines are sold separately.
The coolant lines for the in and out both use the 24" straight -6an lines.
https://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Product_Code=ATP-FTG-028&Store_Code=tp
Let us know if you need the fittings as well.
And the fittings:
2 x of the banjo fitting kits and 1 of the rest of the fittings
https://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Product_Code=ATP-FTG-145&Store_Code=tp
https://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Product_Code=ATP-FTG-022&Store_Code=tp
https://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Product_Code=ATP-FTG-048&Store_Code=tp
The last fitting we do not have listed on our site.
Fitting: 5/16 male pushlock barb to -6 male female, straight
If you plan on placing the order for the parts, you can order this
fitting and send us an email and we can replace accordingly.
https://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Product_Code=ATP-FTG-117&Store_Code=tp
Corpus Christi
I will absolutely second that the coolant lines are brutal to get installed. I will say that it was easier putting them back on the second time once everything was lined up though. I wish the wastegate had just been in a better location so I didn't have to take the turbo back out in the first place! My buddy got a new Civic Si and his turbo is right at the front of the engine bay...must be nice! haha
El Paso
Turbo on the Si is a tad bit easier to work on but there is alot of negatives , the biggest one is weight balance , this is big especially on a front wheel drive car where most the weight is in the front anyways and adding all that weight to the nose of the car can really make a difference. Having the turbo in the rear also makes pretty much anything else on the engine alot easier to work on.
Pittsburgh
Ok guys another question as I received my kit today and now I’m crazy excited for the weather to warm up. How much physical adjustment was required to get your car running right after your install. By that I mean, did you just slap the MRX on and get it tuned? Or did you have to make adjustments to your wastegate, bov that you chose, etc? Also, I did not get the adjustable wastegate actuator, did I make a mistake? Did any of you find it to be essential?
Lawrence
I hate to ask as I am unsure if it has been stated already within these 145 pages, but, can anyone attest to the reliability of the MRX over 10k miles? 20k miles? I am not looking for over 270hp, looking for fun and reliable. I scoured these pages and from what I have read I am seeing mixed reviews and looks like no one has had issues other than fun factor down low.
It's a Garrett turbo made for mountune....their reliability is Better then the Hybrids if you do little reading. So it's made for the long haul and by a respectable business that's been around a little bit.
Lawrence
I have done a lot of reading, thank you for the response. I know that Mountune and Garret are both reputable vendors. I am looking for real world results from people who have put some miles on these things.
Toronto
Garrett is a manufacturer not a vendor. Typically garrett turbos are all oem quality and don't fail from normal use.
Its a manufacturer for 3m/Honeywell ...Jesus do we have so technical here...do you want a tour of the factory also? I can get that arranged...
Toronto
Sure, why not. There is a significant difference between a vendor and a manufacturer, especially when speaking to levels of quality and perhaps the poster is unaware of that.
Toronto
Let me reword my question: How many miles have you put on your MRX turbo?
You really don't have to worry, it will last you 100,000 miles easily at the power levels you want. Consider it to last as long as the car, just as most oem turbos do.
