I went with westcoaST's Mishimoto OCC setup. Not cheap, but pretty slick. Pretty close to plug and play, but you have to order hose if you don't want to use the provided stuff (which is probably enough, although I did not check).
We had extra wire-reinforced hose, so used it on he input side. Thank you [MENTION=411]westcoaST[/MENTION] for your suggestions/guidance.
Sorry for the hijack...we now return you to your normally scheduled programming.
