Misfiring after spark plug replacement?
Summerville
So today at 24k miles I decided to replace my spark plugs with NGK one step colder. This is my first time gaping plugs, but I feel confident I got them all between .028 and .029. I am currently running an e30 tune. I had a bit of an issue where it appeared that the coil didn't have a good connection to the plug. After troubleshooting it appeared to be ok. After a test drive for ~30 min cruising with 3 3rd gear pulls I registered 10 misfires. I've never monitored misfires before, so I don't really know if it is a normal or not. I also noticed that I had a knock on cylinders 1 and 3 which I've never had on this tune. Is it common to have misfires like this, should I look at replacing the plugs with a normal heat range, or is there any other troubleshooting that anyone can recommend? Thanks for the help!
forevercasual
Summerville
Thanks for the link. Guess its better to be safe than sorry and get another set.
me32
fairfield
Did you make sure all the plugs are seated all the way down?
