Thread Starter
My car tramlined with the RE50’s. Once I put the Feddys on excessive tramline went away of course I should say I tortured the RE50’s. lol
As I did not even make 10k on them.
You are right about Pros and Cons to both I do have a bit of toe on my car right now and I am going to be dialing in more negative up front after I put my Camber plates in the rear. I also decided to install the Hotchkis rear bar after putting my rear Camber plates on. It should be interesting.
My car also pulls street duty and hopefully should see the track one of these days. Though that is hard to predict when given the current situation.
Toe in or toe out really depends on each person's driving style. I run 1/16" toe IN. I prefer toe in because I run bigger, more open tracks and I feel that toe in makes the car more stable at higher speeds and under hard braking. If I did AX, then I would prob want toe OUT which would help the car rotate quicker, and since AX is generally slower, there isnt a huge need for straight line stability with high speeds and hard braking. That's just my personal opinion tho. Everyone likes their own personal set up.
I have tried pretty much every setup for the rear. Sway bars, torsion bars (race and street) made the car unbalanced. They caused alot more oversteer and made the rear too stiff. Now, I'm not running anything in the rear. Super stiff isnt always the answer. Just my .02.
Looks like the tracks might be opening back up next month. I just got an email this morning. Keep your fingers crossed and maybe we can all get back to having some fun. Lol
