Low frequency vibrations clutch out in neutral
gtx3076
US
Just noticed it yesterday. 2014, 143k miles. Pretty sure the original clutch. When I clutch in it goes away and I see the rpm’s come up to about 800rpm, when I let the clutch out the rpm’s dip and stay down around 740-760rpm.
Massachusetts
Sounds like the clutch is dragging on the flywheel a little. Had that problem on a previous car caused by my throw out(thrust depending on manufacture nonmeclmeture) bearing being toast and catching on the output. Hopefully that isn't the case for you as I needed to replace the clutch,fly wheel and get the crank replaced as the output shaft took a beating and filing and sanding smooth would not work. Was expensive back in 2007 so I can't even imagine what it would be like now. Could also be a myriad of other things as my issue was on a 1995 Saturn SL2 5spd(RIP my little Honda eater) lol.
