Greetings folks,
Since I purchased the car there has been this noise coming out from the armrest area:
https://youtu.be/hpSQCqgR8ME
The noise will stop if I put pressure on the armrest or console base from the side, i.e. push them from the side.
Initially I suspect it was something with the storage cap, which I took it off and put some sponge at the metal/metal contact points, but the problem persists. I tried remove the entire console base and tighten every possible screws I could see but it didn't work. Right now I'm suspecting it is from the USB/SD Card port inside the armrest storage, but again it doesn't make a lot of sense because pushing the console base/armrest to stop the noise has nothing to do with the port.
I'd appreciate any input on this. It's pretty noisy and almost intolerable. I feel like my car is falling apart sometimes.
Thanks a lot!!
Thanks a lot!!
