Loud bang
Marcellus
So I left work last night and there is a transition that isn't very steep. I turned out and went over the transition and heard a loud bang. Now I get this same loud bang during any type of aggressive shift. The car is stock other than the Cobb RMM. I checked all motor mounts and everything is tight and correct. Any ideas would be appreciated. I only have 500 miles on the car.
CanadianGuy
Southern Ontario
Do the dealerships normally have an issue with the aftermarket RMM? Doesn't that technically void warranty?
Only if it is the cause of the problem. But if you are concerned and have the oem put it on, but i really doubt unless it is the broken part ( could be ).
D1JL
7000 Post Club
U.S. Navy Veteran
SFV, So.Cal.
Some people have had issues the other motor mounts on the Fiesta as well.
If that turns out to be the problem the dealer could say that the Cobb mount may have caused it.
We know that is not true but it depends on the dealer.
Dave
me32
fairfield
Maybe you broke the bolt on the motor mount under your over flow tank.
P
Marcellus
Update: So after going through this car with a fine tooth comb checking everything that could make the noise, I could not find anything wrong. I also cannot get it to make the noise anymore. Have no idea what it could have been, but I am happy its not happening anymore.
Dearborn
Glad to read this issue seemed to resolve itself, placemarty! :) You know where to find me should you ever need anything down the road - don't hesitate to reach out.
Nick
