The battery in my 2018 that i just bought is original, and I can tell it is dying (6 years old). After doing too much reading, going back and forth between AGM/lithium, and taking cost into account, I decided on a 15lb Deka battery, ETX20L. Apparently they make this battery for most auto parts stores, including braille, napa (napa legend premium agm) and autozone (duralast gold agm), and probably the oreilly battery also. It is 310CCA, 17.5Ah @ C/10 discharge rate, and weighs 15lbs, much lighter than the stock 31lb brick. The cost was $120, which is much less than the 5lb shorai LFX36L3-BS12 and costs $325 ish. I will monitor the voltage and performance of the Deka, hopefully it will last at least 4 years. I am in San Diego and don't plan on driving to a sub zero place any time soon, but I should invest in some good jumper cables just in case lol.
The other things I'm curious about is what is the draw on the battery in full shutdown mode, and can I install an automatic disconnect to remove the battery from the circuit once voltage reaches something like 12.2V. I have some experience with BMW Intelligent Battery System, and ford's is very similar (I assume all new cars have a IBS of some kind now). I still need to get forscan and code in the new battery specs, just like I had to do with my e90 330i when installing a new battery.
