I have only installed 205/45/17 that are a fairly wide 205 and a bit taller than stock tires on 17x7, +40mm on my lowered as far as I can go and have good geometry so not that low and no issues but I had already trimmed the bottom bolt location in the front wheel wells that holds the fender and bumper together. Three bolts there so no worries to take out the bottom ones and trim off the tabs. I had to do this for my very wide race setup, not sure if needed on other setups.
There are many running different size tires and offsets, rim widths so you will have to dig in and find the info or ask around, searching first is the proper way to do so of course![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
