I am considering buying an 08-10 Rav4 Sport V6, 276 HP, AWD, pretty peppy and decent handling little SUV. It comes with 235/55/18 tires on 18x7.5 pretty heavy wheels, tires are not that low in weight either.
I have been promoting lower weight wheels and tires for decades and my SUV, trucks, etc all get consideration since it effects everything on them as well, handling, ride, wear and tare on the suspension, road noise, fuel economy, etc.....
I can get some nice flow formed 18x9, 19.5lb, Konig wheels for $250 each or 21.5lb ones for $210 each and the ultra high performance all season tires would be 255/45/18 RE970 AS Pole Positions, 29 lbs, $176 each or the same size in the SC-2, $157 each, same weight, 48.5ls is pretty dang decent for such a great setup and very reasonable cost.
I might upsize to 19x9.5, 21.5 or 24lb wheels for around $200 more, tires would be 1 lb heavier in 275/40/19 in the Pole Positions and another $200 gain in cost, total weight would still be just 51.2lbs.
The SC-2 AS is 3 lbs heavier and close to $200 more per set compared to the 18's and just $150 per set less than the PP so I would have to consider that.
Also the 275's are getting pretty wide for the weight of the Rav4 in slippery conditions, best to not go to wide or just not enough PSI on the ground in the rain, mud and snow besides having to plow through it.
Compare that to running stock wheels and 21lb tires, 45+lbs on the FiST, stock on the Rav4 is likely around 58-60lbs, my 15x9 race wheels with 225 slicks are 30lbs as are teh Rival S street tires I run.
WHY did I post this?
Just a heads up that there are great reasonable cost performance and appearance upgrades even for SUVs, trucks, etc......and it does matter
