So I had a bit of an adventure with my axle seals. I'm gonna give the shortened version but it was a saga. My car shipped with the metal flanged axle seals (I have a 2014). Started leaking at 30k miles, took the car in. The dealer said they replaced them (debate-able). Leaked worse at 33k miles, took the car back in. The dealer said they replaced them (doubtful). At 36,001 miles (warranty expired) I had fluid on the whole bottom side of the car. Took the car back in, 4 days and a loaner car later I show up early to check my car out on the lift with the service manager. This time instead of the metal flanged seals, Ford had realized they were a problem so they obsoleted the old part number and now superseded it with a completely rubber seal. 10k miles and no leaks.
Take aways:
* So if your car has the metal flanged seals, it is probably gonna leak.
* Its complete BS and should be a recall/TSB.
* The dealer will probably give you the run around like I got.
* If they replace the seals in your warranty period, you have an additional 2 year warranty on that part.
* If you are out of warranty before you take it in for the first time you are SOL.
Edit: found a pic of the old seals on my phone. This is the metal flange seals that leak.
Here is what the New design replacement seal looks like.
Take aways:
