As the title says, there's some knocking noise when I'm taking right turns and going over larger bumps/humps when the passenger side strut is unloaded. The noise seems like it's coming from the strut sometimes, but others it sounds like something is loose and banging about right between the shift knob and dashboard on the passenger side. Sometimes i can even feel it in the shifter knob. There is also occasionally some squeaking from that side as well. Seemed like everything was tight when I checked, no other parts seem loose. Given the location of the sound I've ruled out the strut bearings.
Only thing I can think of is the sway bar end links, I can move them by hand about their joints, but they seem pretty tight and there's no obvious free play. Again, given the location of where I'm hearing the sound I'm not so convinced it's the end link. I also haven't been able to find any other threads about failed end-links, are they a common failure on the FiST?.
edit: about 75k mi on the car. Daily drive and auto-x it, OEM everything when it comes to suspension
Thanks in advanced
Thanks in advanced
