Keep radio on after shutting off car
Jupiter
How do I keep the radio on after I've turned the car off? For example at the Drive-In? It stays on for about 10 minutes if you don't open a door, but shuts off as soon as you open a door.
stuntdoogie
NYC
I dont think you can but if someone knows a secret, let us know cause enquiring minds wanna know!
rodmoe
wausau
No Nav and I get the 10 minute shut down like all my past cars all i do is cycle the on off switch or push button depending on car If i recall correctly
TheStig
Phoenix
don't press the clutch, press the start button once or twice and it will go to accessory? I mean your lights and stuff will be on.
Sekred
Mid North Coast
With the key fob within range, like inside the vehicle, push the radio power button. Radio comes on without the ignition. To switch the radio off, push the button again. Do your NA vehicles have a power, on/off button?.
Perry
Leawood
Don't depress the clutch; push Start button and hold for a couple seconds. Electrical systems come on; remain on for 30 minutes, I believe, or until someone opens door or turns things off by pressing the Start button.
Perry
Leawood
I would like for only the radio to stay on tho
Ah. I've not had a car that would do only that since probably 1983. Turning to the "Accessory" position I think always allowed for whatever electrical items to run, etc. With the audio wrapped up in the Sync/My Ford Touch device, I don't think it's possible to have just the radio on, though I'd be happy to be proved wrong.
stuntdoogie
NYC
All my previous hondas had the option to keep just the radio on. Never had to go to ignition on position.
Perry
Leawood
Huh. I didn't know my Hondas would do that. At any rate, sorry I can't be of more help. I'm tapped out on this one.
Toronto
My Yukon stays on till a door opens...actually, everything works till the door opens...windows, wipers..etc...
This worked for me...door opened and everything...I've been trying to figure this out since I got the FiST in July lol...thanks Sekred
Just a update...it still shut off on its own after a bit
haste
Eastern
My '02 Focus SVT radio works for an hour until automatically shutting off if turned on without the key in the ignition. I imagine Ford has implemented something similar into their newer vehicles...
San Diego
If you want the radio to be on while the car is technically not.. all you have to do is push the power button on your dashboard to turn on your ford my touch screen. It should stay on for an hour or so
philly
I am trying to find out how to set the radio off when I shut off the car. With push button starts, I always have to remind to look at dash if the car has been shut off or not because the radio is on even when I shut the car off.
So the problem is, the radio doesn't shut off when you open the door with the ignition off?
If the radio doesn't automatically shutoff after ten minutes or so, that would make for two different problems.
Does the vehicle recognize when the driver door is opened/closed?
danbfree
Tigard, Oregon, USA
I find it super obvious when I turn off the car and the radio stayed on, but I added the Climate screen with Forscan and now can't get it to stay on for 10 minutes like I want, it's now is stuck turning off with the engine.... SOOOO, I think it's easy to say that it's very easy to change a bit in Forscan and disable that completely if you want, hehe... I joke but seriously, it's pretty easy to do with a OBDII adapter and a Windows PC, you literally just change a 9 to a 0 and hit flash and it's done.
