Ever since I had the clutch slave cylinder replaced the car has a vibration under hard acceleration. I took a video of the RMM when dropping the clutch at idle in 1st and then reverse. Is this movement normal? Not sure which engine mount is bad or if it could be something else. Cruising at low or high speeds there is no vibration.
