Hi all, today was pretty cold 11 to 8 degrees C. I warmed the car up and and drove gently till it got to about 70 degrees. We went up a hill to a scenic spot but when we went back down the engine temperature got as low as 46 degrees... My thermostat must be stuffed? Because the heater wasn't as hot as it should be either so it's not like the temperature sensor is out... Couldn't give it the beans because the temperature is too low.. Just cause engine damage. And even the cars OEM temperature gauge showed 3 bars. I use the torque pro app to monitor the engine information. Looks like a big job to replace the thermostat too..
