Intake Valve Walnut Blasting - My DIY Experience
jtl
Sandy, UT
I finally got my 2015 running again after some extensive (to me) repairs that I did at home in my garage. At some point in there I popped off the intake manifold and had a peek at the intake valves.
They were pretty nasty looking after 130k+ miles of my typical spirited driving (including several track days and many more fun days driving to ski resorts on snowy mountain roads).
They all had build-up, but some of them less so than others.
By this point, I was having a myriad of issues including misfires, blown out spark plug threads, and loss of performance. Now I can't attribute all of those symptoms to gunked up valves, but I'm sure the valves weren't helping anything.
I generally followed the set-up described on the Focus ST forums here: https://www.focusst.org/threads/how-to-walnut-blasting-intake-valves.119770/
A few key differences in my approach:
  • I used a lot of frog tape to cover up ports I wasn't blasting. I also used it to cover up any other holes (vacuum lines, bolt holes, etc).
  • I didn't bother laying down blankets. I'm not too keen on keeping things show-ready, it's just not my style! If you want to keep things clean though it's not a bad idea.
  • I used a custom-made adapter similar to the one linked on page 2 of that same thread: https://www.ebay.com/itm/Ford-Focus...-Cleaner-Walnut-Blasting-Adapter/113708286072
A note on that adapter: I shot the seller a message asking if he could make one for the 1.6L EcoBoost. He was happy to design and manufacture it for me. I just needed to send him a few photos and measurements of the valve ports, and within a week I had from him two adapters to try. They had slightly different designs, and ultimately I used the black one. (So if you're reading this and looking for an adapter that he doesn't make, even if it's not for a Fiesta, shoot him a message!)
The blasting itself was straightforward. I highly recommend using an air compressor with two outputs - one for the walnut blasting, and another with a basic air gun attachment to displace the stubborn bits of walnut that don't want to be vacuumed up. Otherwise if you only have one output/hose you'll have to relieve the pressure, switch tools, set the pressure, blow some air, relieve the pressure, switch tools, set the pressure, blast some more, relieve the pressure, switch tools.... it goes much much faster and you're less likely to cut corners.
I didn't take a picture of the blaster or the air gun in-use. But they go into the hole on top of the adapter. Nothing complicated.
Each valve got repeated walnut blasting followed by blowing out the walnut with compressed air with the shop vac running the whole time, until I was satisfied with the results.
Here is a side-by-side of before and after I cleaned the first two valves.
All in all, the walnut blasting process itself was tedious but not difficult. I think the hardest part is removing the intake manifold due to everything else that needs to be removed along with it, but between YouTube, forum posts, and service manuals, that part of the job isn't too bad either.
Performance-wise, it feels like a new car again, but like I said earlier there were so many issues that it's hard to gauge how much these valves were hurting things.
I'm no expert, but I've been learning a ton over the past six months (how can anyone afford a mechanic these days!?) and I'm happy to answer questions or go into more detail about any part of it if I can. Hope someone finds this info helpful!
Greenville, NC
I'm about to embark on this journey myself. I've got a 2015 with 163k miles on it, COBB tuning access port, Whoosh! Hybrid Turbo, MishiMoto intercooler, 3" catted downpipe etc., and have been running the 93 octane tune on the cheap stuff and it has been an absolute blast.
Yesterday the car started running rough on the way home from work (60 mi each way), and I got Misfire on Cylinder 3 code. The engine light has been on since the tune- something about the cat, investigate if performance issues present themselves etc., but the light was blinking.
Pulled spark plugs this morning and #3 was far darker than the others - hell, one was loose.
I'm considering buying the walnut media blaster on Amazon and doing it myself since the closest blasting service is in Raleigh, ~85 miles away (I'd trailer the ST behind my Taco), and costs ~$1,000.
Whereas the media blaster costs ~$340...
Looks like I'm giving myself a crash course in engine teardown. I suspect you and I are comparably qualified heading into it, so I'll be leaning heavily on links and advice.
About how long did it take you?
Woods247
Atl
Nice work! Thanks for posting this. I gotta get around to it myself..
J
jtl
Sandy, UT
The car spent three or four months in my garage while I slowly worked on it. Again, I did a lot in addition to the walnut blasting. I spent a long time waiting on parts and tools which could have easily been avoided if I were more careful.
For example I chipped my crankshaft pulley trying to remove it and since the part was backordered I found one on eBay that shipped from Latvia and took a month to arrive. Another example was breaking a bracket because I glanced at the wrong line (picture goes with the text BEFORE it, not after) and torqued what should have been 89 in-lbs to 59 ft-lbs disregarding the thought of “man, this seems excessive”.
If I had to guess, I spent maybe 40 hours of time on, under, or around the car. Just a guess though.
Greenville, NC
Me & my buddy got everything removed, valves blasted, and I got it reassembled in about 10 hours, which includes going to lunch.
Turns out the root cause of my misfires on Cylinder 3 is a bad injector, which should arrive by Friday.
