Hi
Currently having some issues with my mk7 ST which I suspect is possibly a leaking injector, symptoms are intermittent loss of power for a second or two on full throttle, Strong smell of petrol in engine bay and sometimes in cabin and occasionally a longer than normal engine crank time before it starts. Car is currently at 70k miles, I've had the exhaust smoke tested to ensure that isn't problem as well as a full vacuum leak test, and cylinder compression test.
I'm planning on having the injectors tested not sure how big of a job this is but I don't think I could do it myself, what I'm unsure about is whether or not the seals need to be replaced when removing injectors?
