Initial MRX Datalogs - 93 octane (running E15 blend), wastegate pressure only
Hela
Looking healthy, just needs some fueling tweaks for the extra ethanol content of the E15 blend vs the 93 setup in the tune. Cant wait to get it adjusted and move the boost on up.
Mississauga
Instead of the graph can you post the datalog numbers? Graphs are great but seeing the calculated load and G/S the turbo is taking in would be much more useful.
S
Hela
Here you go, tiny... lots of data! :) This is wastegate pressure only, non-billet WGA on the MRX. Fuel is 1 gallon of 104 octane E85 added to 11.2 gallons of 93 octane pump, so net of about E16, 93.9 octane.
Vero Beach
Test this mix against regular E15?
It's a lot cheaper.
On the gas station I go to, 1Gal of E85 + 9 Gal of regular fuel = much more expensive than E15 by itself, or even a blend of 50% E15 and 50% regular.
