Parts Needed:
This is the least serviceable design I have ever seen.
- Timing Tool Kit with all pins and flywheel lockout via starter
- Right Axle Bear Clamp (YS4Z-3N324-AA)
- Crankshaft Bolt (BE8Z-6A340-A)
- Timing Belt (BE8Z-6268-C)
- Timing Belt Tensioner (BM5Z-6K254-A)
- Water Pump (7S7Z-8501-C) and gasket
- Right Motor Mount
- Serpentine Belt
- Serpentine Idler Pulley
- Thermostat (it's on the other side of the engine)
- Valve cover gasket
- Getting the starter out was NOT easy or by the book. It is cramped, there are nuts that come off and could fall into the bell housing. TERRIBLE DESIGN
- Getting everything off was lengthy but not hard.
- Be prepared to break clips and clamps at 125,000+ miles
- The toolset sucks to use. A pin in the block? And a flywheel hold? And a vibration dampener alignment all because you didn't want to key the crank pulley and vibration dampener. TERRIBLE DESIGN
- I got the timing belt on. Tightened a brand new pulley bolt (90nm + 90 degrees +15 degrees) OMG
- Pulled the tools, rotated and it lined up. Rotated again and it lined up. Rotated again and it lined up.
- Put it all back together
