HVAC help, temp door actuator
Usa
Hey all.
I have an HVAC issue, the cars only blowing hot. After much diagnosis, the AC compressor is working fine, however the temp door actuator is not. This is the servo that directs air to the cold or hot side of your HVAC. Now im trying to get at it, and im wondering if anyone has any tips or tricks to get this without having to take off the whole dash as its throughly wedged between the center column and the lowe dash.
Thanks in advance
lorton, VA
I did it without taking the whole dash out. Remove the glove box and there are 2 vents you can pull out in the center console area of the glove box opening. top bolt is easy to get to. I used a mini ratchet to get the bottom bolt. out.
