HVAC Control Problem
Cincinnati, OH, USA
I’ve recently ran into a problem after replacing the recirculating actuator, the controls for my HVAC no longer work. When I hit the “OFF” button air will blow through the main vents at full speed, the fan speed is stuck completely on 24/7, the auto button no longer works, AC will turn on even if the button isn’t on.
Anyone have any clues? I have unplugged the battery and tried switching actuators.
I do have a code in the BCM and TCM for “b1d34-00”
Jabbit
New England
If you find out it's the physical buttons, I have a gently used set I could sell you.
