Maybe a dumb question but just want a general idea what you guys think. What am I missing? Also have a single port kit from whoosh and was wondering opinions on if throwing that on would lower the reliability enough to where I should stay away from doing it? Cheers
Build list
Roughly 304whp/340wtq
Maintenance:
Motorcraft yellow coolant: 63,000 @93k
Brake fluid/clutch fluid: 57,184k @ 87,184k
Motorcraft 5w-30 oil: 65,778 @ 68,778
FL-400s oil filter: 65,778 @ 68,778
Motorcraft XT-11-QDC Trans fluid: 56,000k @ 86,000k
Coil packs: OEM
Spark plugs: 65,778 @ 75,778
Front brakes: 53,869k
Rear brakes: 42k
Intake filter cleaned: 57,398k @ 67,398k
Intake filter: 11/21
Battery: 2/2021
Serpentine Belt: OEM
Timing belt: OEM @150k
Hoses: OEM
Cabin air filter: OEM
Toyo hp 2 a/s 4: 64k
Oil catch can emptied: 65,778 @ 68,778
Windshield wipers: 4/22
Alternator: OEM
Timing belt: OEM
Walnut blast intake valves: @100,000k
Miles:
Motor: 66k
Trans: 34k
Clutch: 24k
Body: 66k
Build List:
Cobb accessport v3
NGK Ruthenium step colder plugs
Cobb accessport mo money face
Cobb accessport a-pillar mount
Tune Plus e30 fuel tune
Whoosh Motorsports Race-Spec RMM
MBRP 3” catback exhaust
Mishimoto air intake system 2014-2015
Whoosh motorsports 3” catless downpipe
Depo racing intercooler
Velossa tech ram air big mouth
Go fast bits dv+
Whoosh motorsports hot side charge pipe
Whoosh motorsports cold side charge pipe
Whoosh motorsports turbo inlet pipe
Silver Tial MVS 38mm external wastegate
Dual spring setup, large black and small red, 1 bar or 14.50psi total
Whoosh Motorsports Hybrid Turbo Setup for EWG
Stock exhaust manifold ported w/ v-band flange welded on top for external wastegate
ZZPerformance Dump Tube on wastegate
Whoosh motorsports shifter base bushings
Cobb cable bracket bushings
Perrin 2” shortie antenna
Billetworkz weighted shift knob
H&R super sport lowering springs
Mishimoto fiesta ST Radiator and Mishimoto fiesta st radiator fan shroud
Whoosh motorsports magnetic oil drain plug
Project Kics magnetic transmission drain plug
Mishimoto thermostatic oil cooler
Mishimoto oil catch can kit
Mishimoto aluminum coolant expansion tank
OEM convert 2016+ evap to 2014-2015
Whoosh motorsports short shift kit
Konig dekagrams
Build list
Maintenance:
Coil packs: OEM
Rear brakes: 42k
Battery: 2/2021
Hoses: OEM
Alternator: OEM
Timing belt: OEM
Miles:
Motor: 66k
Trans: 34k
Clutch: 24k
Body: 66k
Build List:
Cobb accessport v3
Go fast bits dv+
Konig dekagrams
