So I did a bunch of datalogging last night on 93, then turned around to get some e30 in the tank, and re-logged in almost exactly the same spots.
Gonna go ahead and post the v-dynos and datazaps, using the settings from the v-dyno thread...
First Pull: Link
This was a 3rd gear 93 octane pull. Here's the v-dyno:
Second Pull: Link
This was also a 3rd gear 93 octane pull, but it had some wheel spin and the v-dyno will reflect that... it's kinda pointless to post, but here you go:
Third Pull: Link
Alright, so this was a 4th gear pull from 2k RPM... lots of surging, the throttle closures don't look to be ideal... you can see how funky the boost curve looks, and you can definitely feel/hear this happen in the car. Is this a tune issue or would it be related to my stock WGA? v-dyno:
Fourth Pull: Link
This is the first of the E30 pulls (3rd gear), and had a little wheel spin... but on the bright side I made 400whp and 600lb/ft of torque. v-dyno anyway:
Fifth Pull: Link
Second 3rd gear E30 pull. v-dyno:
Sixth Pull: Link
Third 3rd gear E30 pull. v-dyno:
Seventh Pull: Link
Fourth 3rd gear E30 pull. v-dyno:
Eighth Pull: Link
E30, 4th gear. Doesn't have the issue that 93 has with the surging? Hmm. v-dyno:
Ninth Pull: Link
Strangely enough, this pull was slightly down hill (down an exit ramp, the only not-flat pull in this group) and it knocked and pulled timing. Wonder if it had to do with wheel spin? Bizarre. 3rd gear. v-dyno:
Tenth and final pull: Link
Actually, looking at it, same issue on this pull. Same cylinder. I have new plugs on order, though... :/ v-dyno:
First Pull: Link
![](http://i.imgur.com/N78bDkC.png)
Second Pull: Link
![](http://i.imgur.com/WRzppAy.png)
Third Pull: Link
![](http://i.imgur.com/KYsroLc.png)
Fourth Pull: Link
![](http://i.imgur.com/ukpScpP.png)
Fifth Pull: Link
![](http://i.imgur.com/VjYu4KN.png)
Sixth Pull: Link
![](http://i.imgur.com/TpEwHLj.png)
Seventh Pull: Link
![](http://i.imgur.com/RkUd0tP.png)
Eighth Pull: Link
![](http://i.imgur.com/1fSjj0f.png)
Ninth Pull: Link
![](http://i.imgur.com/Gb6NefH.png)
![](http://i.imgur.com/jnFOufN.png)
