Hotchkis swaybars
Woods247
Atl
I am not trying to start any controversy here but I had a similar issue.
I use the Ebach (available sooner & free) rear sway bar, not that the bar should make any difference.
I found that the issue you are describing in my case was cause by the rear brakes.
By increasing the gripping force of the rear brakes made this problem go away.
Again, this just the way I solved it.
Same here. Installing a front BBK without doing anything to the rear made it worse. Balancing the brakes has helped tremendously. Even with rear camber it would wag like crazy haha.
