Good morning all, I am in need of some help. I continually keep turning up with nothing.
This is for a 2015 Fiesta ST with 75000 miles on it. maintenance is up to date with having a coolant flush not more than 10000 miles ago, I swapped the coolant tank and used the standard Dexcool orange that the car calls for, AC works fine.
I switched out my cracked coolant expansion tank and the return coolant hose that also had a leak, I went with an aluminum Mishimoto expansion tank and got an OEM coolant return line. Switched all of that out, burped the cooling system topped off the coolant, now my heater doesn't work unless I get it to higher rpm range on the freeway, then the heater (mainly defrost is what I'm needing this time of year) blows hot and works just fine (telling me that its not a blend door actuator or anything), but I can leave my car running to warm up in the morning with nothing but cold air blowing through the heater.
I have switched out my cabin air filter and vacuumed it/ blown it out, I have had a shop pressure check my cooling system and they saw nothing of any significance, said they got a couple little bubbles out of the system but said my coolant expansion tank replacement job was fine and didn't say I messed anything up. That shop was saying their next step would be to do my heater core which I really don't want to have to do, and my warranty won't cover anything unless there is a leak coming from the actual heater core. So I am hoping there is something, someone on here has dealt with and fixed that can give me some advice. It is getting very frustrating not being able to defog my windows and this has just kept following the trouble tree of deeper head scratching.
I appreciate your time and hopefully we can come up with something. Thank you.
