Godspeed MonoSS Coilover install guide and review
Can Godspeeds be raised up more than factory ride height any? Is it a pain to adjust them any also?
Maihyo
Thread Starter #22
I cant say for sure, but I'm condident it can reach stock ride height. I did manage to cram 225/50/16's on my car(with many issues not related to ride height)
I wish there was a set of coilovers that would raise the vehicle up more than factory ride height for those who rally or want to be up higher due to inclement weather/ The Devils dandruff!
PunkST
^ have you looked at the DNA camber plates? That might make the setup pretty much perfect.
If youre liking the godspeed coilovers thats really good. I'll check that other setup too.
MagnetiseST
^ have you looked at the DNA camber plates? .
Not sure if they'll fit properly, it depends on the diameter of the strut rod of these coils.
I'd rather spend the $ on silvers or fortune and do it once instead of $600 on coils then $360 on the DNA parts.It works out about the same.
Maihyo
Thread Starter #27
Im running the dna rear camber plates, they make a front camber solution as well?
PunkST
Yes. Upper camber plates with two strut rod diameters ( so you will have to measure). And also front control arms that probably give a bit of adjustment as well.
Maihyo
Thread Starter #29
Good to know, Sounds like some good christmas presents to myself lol
PunkST
I want a lot dna's offerings. Gotta watch my money though
#33
I as well have Godspeed mono SS, and after almost 13,000 miles on my behalf and roughly 10,000 from the previous owner (slammed) I can honestly say that they are still holding up. I don't know how exactly but they are, I wouldn't suggest these really for anyone. Unless you're the type of person that just wants coilovers at the cheapest possible price.
Sent from my moto g(6) using Tapatalk
#34
oh that isn’t very reassuring, what don’t you like about them?
#35
The only thing I've found off putting about coil overs is that you really should get an alignment after you adjust them up or down to be properly correct*
#36
A proper alignment is key. With Godspeed you get what you pay for, there are slight improvements compared to the OEM shocks and struts. It does feel less jarring around town in certain spots and far less want on the freeway, but the valving chosen by Godspeed does not feel right, the car felt imbalanced. Recently after adding a trunk brace and camber plates to the rear via Dpro the car now feels balanced/square as it did when I bought it.
The coating is chipping off slowly due to surface rust underneath. Adjustments knobs are not the most precise, not like Koni's. Although the Godspeed rear cartridge is easier to adjust than koni.
TemecFist
#37
What kind of end links did you go with for the front?
#39
what did you end up going with?
Stayed with NOS shocks and struts with Type R lowering springs. Didn't wanna deal with constant adjusting and paying for an alignment checks*
