Hi,
I’m looking to change the gearbox oil in my car. It currently runs Castrol Transmax FE75w.
I’ve been reading through the forums and can see that a lot on here recommend ravenol mtf-2 75w80. Is there any benefits to changing to a slightly thicker 75w80 oil from the standard 75w?
Also my car runs a gripper plated diff. The oils recommended for these tend to be GL5 but I’ve heard that these oils are too slick and can damage the synchros and cause poor shifting.
I spoke to Gripper and they said that their diffs tolerate a lot of different oils and to go with the car’s recommendation.
For those of you running plated diffs, what oil do you use and do you add a friction modifier to your standard oil?
