Hi guys I’ll appreciate any help or knowledge but just recently got a 2860 r kit installed on my 18 fist and went into tuning, at the beginning I was only reading 9 psi so I guess I had the wrong spring in the tial bov and the rod needed to be adjusted on the wastegate and they needed to correctly set the preload, after that happened I’m now reading 18.9 psi. Is this normal or should I be reading more? And if so what could it be? All work was done by a shop
