Well this install was very simple.....but just thought I'd share.
Tools were
* 3/8 Ratchet
* 3/8 long sockets
* 8 inch 3/8 extension
* knee pad because I'm getting old
The Garage Line spacer is a very tasty nicely put together piece.
Here are the 2 nuts that need to be removed. The nut on the far right doesn't need to be touched. Just the top left and bottom left need to be removed.
There is a connector up on top that need to be removed IMO. Unless you have small hands and are Carni-folk with a slight aroma of cabbage.
Unplug and remove Gas pedal Assembly.
You can install the spacer on it outside of the vehicle or install it while the pedal is out and then install the pedal on the Spacer. I chose to mount it on the vehicle then install the pedal onto the spacer.
I'll admit it's weird at first being so close together with the gas and the brake pedal. But so so much easier to Blipshift when down shifting. Enjoy!
Tools were
* 3/8 Ratchet
* 3/8 long sockets
![](https://uploads.tapatalk-cdn.com/20210313/af6564ab84095b467b662caf05e4bec2.jpg)
![](https://uploads.tapatalk-cdn.com/20210313/1f0b4ccef8a75e4956231b2fc0fe8157.jpg)
![](https://uploads.tapatalk-cdn.com/20210313/6b12a22b269469acf166787750ea593b.jpg)
![](https://uploads.tapatalk-cdn.com/20210313/bce37c208edcf8f897a7c324a5ab8288.jpg)
![](https://uploads.tapatalk-cdn.com/20210313/304e7e2a4169f4e11b9b9c007c1048dd.jpg)
![](https://uploads.tapatalk-cdn.com/20210313/aa4740a9a11e279a18b69ac4b4b75837.gif)
