Fuel delivery issue?
T
Austin Area
Thread Starter #25
2014-2018 Fiesta ST FORD OEM Cam Bucket at 110k miles. I was expecting to see more wear on the cam side, but evidence points to more wear on the fuel pump side. Note the concave wear.
T
Austin Area
Thread Starter #26
So, the replacement of the fuel pressure sensors fixed the fuel issue. Not positive which one because I replaced both low and high pressure at the same time.
Immediately, thereafter, the “Help! Low boost - new sound” thread issue occurred.
Keeping me on my toes!
Rocketst
Chesapeake, VA, USA
Do you have part numbers and locations for these things? I'm pretty sure I'm having a similar issue. Lowside fp actual pressure at idle is 102psi and I think it should be like 70-80.
PunkST
Menasha
Ill have to re marry my AP and see if this is whats causing my bucking while accelerating on the freeway issue i was chasing last summer. ( itll more than likely come back this summer too) no codes yet for me. Im at 104k. Roughly where are these sensors located in case i have to replace them. ( should also do the cam follower...)
