Hi everyone. I'm new to the forum. I've been looking around for a while, and I picked up a FiST this past summer. It now has 96k miles.
I've been having some type of fuel issue since the fall that I need some help with. I noticed my car started stalling shortly after startup, but only after longer drives. For example, if I drive 40 miles to work, then leave again after 10 minutes, the car will stall withing the first 500 yards. It will start right back up. Sometimes it stalls twice and starts right back up each time, but after that it works fine again. It only does it after a warm start. At first I thought it might be the "stalling after gas up issue" but then realized it's not just after getting gas. It does it no matter what the fuel level is. I always use "top tier" gas at 91 octane, which is the highest we have in Utah due to the altitude. At first I used to top off, but then read that I shouldn't. I've replaced the parts that would have been affected since then. The car has an accessport v3 with mountune tune, mountune intake, mountune intercooler, mountune rmm,
When I got the car, the hoses were broken off from the evap canister. It ran fine for a few months that way, so I just left it. One day it stalled in my driveway, and it's had this problem ever since. I started getting some intermittent codes (P0087, P008B, and U1007), but they didn't return for quite some time if I cleared them. I've since replaced the evap canister, the solenoid, the HPFP, and the valve up front. The low side fuel pressure has been at 108.8 to 108.9 regularly with the fuel rail pressure running as needed. Now the problem is occurring much less often, but I'm noticing zero psi on the low side most of the time. It runs and starts fine, just not when it's warm and has sat for a few minutes.
Here's what I'm reading off the accessport at idle and at speed.
At idle:
FRP Actual: 604 (558/2275)
Lowside FP Actual: 0.0 (0.0/108.9)
Actual AFR: 14.55 (11.47/43.37) - the high numbers are when coasting down hills in 6th.
At speed (not full throttle):
FRP Actual: 1879 (547/2265)
Lowside FP Actual: 0.0 (0.0/0.0)
Actual AFR: 14.41 (11.61/43.22) - the high numbers are when coasting down hills in 6th.
Thanks for any help in advance.
At idle:
