Front RMM bolt is stuck or broken, what to do?
Colorado
Howdy, tried to replace the stock RMM today but when attempting to remove the front bolt, it would 'skip' or 'jump' instead of spinning smoothly. The bolt will wiggle around in the mount if pushed (see video). PB didn't help, nor did a jack under the engine so I left it in place in case I need to drive it to a shop. How should I proceed?
View: https://youtu.be/abY4A3bl8GI
Tallahassee
Is it possible that someone may have accidentally reversed the RMM bolts? (i.e. put the shorter rear bolt in the front and the longer front one in back)
