I put the corner tints on this morning. I have never put on vinyl before. It was very easy.
1. Clean area with rubbing alcohol.
2. Spray down area with a lot of soapy water.
3. Peel sticky side off, place on light. The vinyl moves around very easily until you start squeegeeing water. Then it will get a little more difficult to move, but not to the point of no return. I got the same squeegee card that James recommended above. It worked great
4. Use a hair dryer and keep squeegeeing the water / air bubbles out.
5. Remove outer protective film and you’re done.
It’s very easy to do. You just need a little bit of patience. At first I didn’t think the tint would be dark enough, but it appears to be the perfect shade.
Some before and after shots:
