Looking at upgrading and replacing my front control arms because the ball joint has gone. Firstly, do I need to replace the bolts with it because I’m not sure if they use stretch bolts or not. Secondly, does anyone have the torque specs for a 2014 ST180 for the 3 bolts that connect the wishbone to the car. And third, is it worth just paying to have it done? I head someone say that lock tight is used at factory and even an impact driver couldn’t get the bolts off. Any other advice is greatly appreciated. Thanks
